MIDI controller to engage 7 pin channel selector
spokenwurds
Joined Aug 6, 2023
43
Idea:
I would like to control my amp’s 7 pin din selector with a pedal that sends midi commands.
There is a very small selection of gear out there that does this and i feel like it would be great to have something i can add to my amp’s chassis instead of having another box to keep track of.
map pin config:
Pin 1. +17VDC supply to pedal
Pin 2. not used
Pin 3. Ground this pin to detect footswitch
Pin 4. Ground/Common
Pin 5. Clean/Bypass
Pin 6. Ultra/Crunch
Pin 7. Effects
How could i go about creating this solution?
spokenwurds
Joined Aug 6, 2023
43
The amp uses a 7 pin din cable to select different amp channels/functions according to the map below:
map pin config:
Pin 2. not used
Pin 5. Clean/Bypass
Pin 6. Ultra/Crunch
Pin 7. Effects
I would to know what type if circuit i would need to design to received a midi command sent from the midi out of my ax fx unit and turn on and off the relays related to the 7 PIN DIN map.
35,284
There is no need to post the same data twice.
So what I read is:
AX FX ->MIDI->black box->7-pin DIN->amp
The black box controls three pins plus common:
Pin 5. Clean/Bypass
Pin 6. Ultra/Crunch
Pin 7. Effects
You can use an Ardino to read the MIDI the commands. That is the hard part. The rest is easy.
spokenwurds
Joined Aug 6, 2023
43
So what I read is:
Pin 5. Clean/Bypass
Pin 6. Ultra/Crunch
Pin 7. Effects
i had a feeling it was going to go the way of an Arduino. Lol
