micro sd write protected not able to format
Picbuster
Joined Dec 2, 2013
1,062
I do have a micro sd working correctly however; it moved suddenly to medium protected (reading files are working).
It's like the lock switch is in the lock position but it hasn't one.
I used all types of methods (Microsoft registry, diskpart and Linux tools).
Looking for software to unlock no success end up with the message medium protected.
But it remains locked.
I can get a new one. No problem 10 in stock but I want to know what the hell is going on inside my little micro sd card.
main reason:To protect my other babies to get limp as well.
Any idea?
PicBuster
Picbuster
Joined Dec 2, 2013
1,062
Great thank you.
An excellent program very useful however; it did not omit the medium protected.
Save will produce that horrible medium protected message.
Picbuster
Picbuster
Joined Dec 2, 2013
1,062
Hi guys,
thanks for your inputs.
The problem remains. It seems to be a lockout.
To reset the protect flag you need to write to the sd but the protect flag is set.
Picbuster
ericgibbs
Joined Jan 29, 2010
21,547
hi P,
This looks interesting, he waffles a bit but it may help.
If you find a solution let me know as I use uSD in a data logger and I may get the same problem.
E
