Micro Joysticks In Place Of Dial On Servo Testers
DragonTheta
Joined Feb 6, 2022
89
Now I have two Arduino Nanos set up wired to each other and wired to the ESC and the micro joysticks. When I am securing the Nanos into position, do I need to keep them from touching anything conductive with their pins or exposed pads. Are they going to short out or something if they touch something conductive
Ya’akov
Joined Jan 27, 2019
10,370
Yes, you should insulate the bottom of the board. I usually use Kapton (polyamide) tape. It’s very tough and very thin.
DragonTheta
Joined Feb 6, 2022
89
Thank you
I've read that it's possible to waterproof RC components like ESCs by applying conformal coating.
Would that also work for a Nano
Do you think that a micro joystick could be waterproofed
DragonTheta
Joined Feb 6, 2022
89
I would like to put a power off switch into this system. It's powered by a 4S lipo and I believe it needs to be able to handle about 27 amps with a large margin.
I want to use switches that have covers over the top of them so they don't get accidentally flipped
DragonTheta
Joined Feb 6, 2022
89
A relay like this one, switched with a switch like this one. If you use a switch with a flip up cover you will turn off the switch if you close the cover, that's how they are designed.
I want to make the system secure with regards to not being able to be accidentally switched. And I want the switch to be on when it's covered. So I could make my own switch covers. Alternately, if the off switch were in the format of a dial, that would make it pretty hard to accidentally turn it off. Is there a such thing
DragonTheta
Joined Feb 6, 2022
89
I read in the pictures it's supposed to be pushed to stop. I can make my own covers for something like this. What is better about this one than a regular flipping one?
I'm also wondering if there's a dial switch that can turn the power off by rotating
Ya’akov
Joined Jan 27, 2019
10,370
That sort of emergency stop button is purpose built as a safety switch. You push down and it locks off. You turn to reset.
An industrial style rotary selector might be what you like. But it's not an emergency stop.
Ya’akov
Joined Jan 27, 2019
10,370
I don't know the force, they are usually designed to be difficult and require a very deliberate push to avoid accidental activation. Those switched are usually between 22.5° and 45° depending on the mechanism.
DragonTheta
Joined Feb 6, 2022
89
Ok, Thank you
I think I mentioned that I was having trouble getting things to work at this point with the Arduino. I may go back to that method and in the meantime I am testing out the servo testers. I would like to wire a micro joystick to the servo tester in place of the dial. How do I know which of the pins on the dial are positive, negative, and signal
Here's pictures of the servo tester
https://drive.google.com/drive/folders/1s-S09mphr1DUJ1Vv_AykW57z6AEFFi_i
DragonTheta
Joined Feb 6, 2022
89
Thank you
How do I desolder the five pins or attachment points on the dial at the same time to remove the dial? It has the three pins plus two anchor points
