Methods to generate a single low pulse ?
Externet
Joined Nov 29, 2005
2,675
A pulse generating circuit senses a DC level increasing from 0V to 5V in about a minute.
When the voltage is increasing and crosses 3V, a momentary low pulse of ~100ms (from +5 to gnd) is desired. --------_---------
A comparator with a capacitive output could do it; can you suggest other methods ?
bertus
Joined Apr 5, 2008
23,001
As you say you can use a comparator to detect the change over 3 Volts.
This signal can trigger a monostable multivibrator like the cd4047, to make the pulse.
Greetings,
Externet
Joined Nov 29, 2005
2,675
Thanks.
Yes, am using a window comparator but the window is detected also when the voltage returns to low, not only when increases.
Miguel
SgtWookie
Joined Jul 17, 2007
22,230
When it's triggered on the falling edge, the output will have a positive pulse instead of the negative pulse. You can use a diode to clamp the positive pulse.
