Method for checking TXBL flag
yef smith
Joined Aug 2, 2020
1,459
Hello,While we are sending data TXBL is zero,onle the sending is done TXBL bit goes 1.
Can i check the 4th bit in this way shown bellow?
Thanks.
Code:
 while(I2C0->IF[4]!=1){}
22,082
I don't think so. That is not one of the usual methods available for checking bits. How you do it is compiler dependent, it may or may not be in the latest C standard, but it was never addressed in the previous ones.
The semantics of your statement suggest an array of some type (byte, char, int ...) pointed to by I2C0
while (((I2C0->IF) & (1<<4)) == 0)
would be closer to the correct syntax and semantics, UNLESS your specific compiler provides a method for picking a specific bit out of a word, something like
I2C0->IF.4
