When it states that the NC is (normally closed until switch pressed) I would think that means momentary.Still don't know if this a latching switch
I can accept that reasoning. But I'm not convinced that's absolutely the case. Especially if this is made of Chinesium. However, I'd lean more toward your reasoning than my abandonment of reason. Still, I've seen all kinds of switches. Latching switches in the unlatched position with double throws "could" be labeled with normal open and normal closed. I suspect. Especially so with switches that have indicators. Sadly the definition and description as well as the functionality of the switch is sorely lacking.When it states that the NC is (normally closed until switch pressed) I would think that means momentary.
