Merging CAMtastic files into a PCB file
SiCEngineer
Joined May 22, 2019
444
I have downloaded the gerber files of a DC/DC converter evaluation board which I need to make some adjustments to. When I import them into CAMtastic, I can see the layers of the board. However, I am unable to merge them together into a PCB that I am actually able to edit. I have attached an image.
I have tried the Merge option in the tools but it doesn't identify them as layers that can be merged.
It also looks as though some of the footprints have not imported into CAMtastic properly... it does say before I import that some files are "too large" and that the origin of the files is "out of range"... Maybe this has some issue?
Thanks in advnace,
J
