measuring vibration using non-contact method
Mohit Sangavikar
Joined Sep 18, 2017
Hi guys,
in our company's previous design, we used piezo sensor to measure the vibration of a device. this "contact " approach is causing us troubles in geting the required certifications.
I am thinking of a non-contact method, something in the lines of laser doppler vibration sensing. the measurement should be done 10 m away from the vibration source(its an oil drilling system) .
If anyone has any leads or source or details or a better solution as to how to approach the problem, it would be appreciated
BR-549
Joined Sep 22, 2013
4,928
What is the mass and size of the vibrating device? What is the displacement of this vibration?
Is the vibration audible? Is the vibration isolated....or in the presents of other vibrations?
What is the environment of the 10 meters?
Mohit Sangavikar
Joined Sep 18, 2017
mass of vibrating device: 50-500 kg (we are testing on a bunch of products from drill machines- power plant turbines)
the vibration is audible
the source is the only device in the plant that would make vibrations so yes it's isolated
a 65 metre x 35 metre factory hall
BR-549
Joined Sep 22, 2013
4,928
Which character of the vibration do you want to measure? Amplitude? Frequency? Physical displacement?
Is there a stationary non vibrating area close to the vibration for reference?
You said it was audible........are earplugs required/advised? Does the tone sound pure or harmonic?
And with those sizes......what ranges of the measured character would be required?
BR-549
Joined Sep 22, 2013
4,928
One simple solution might be a laser pen, a reflector and some graph paper or a wall projection.
or..... another solution might be a magnetically attached and aligned wireless accelerometer.
It all depends on what you are using the vibration measurement for.
Janis59
Joined Aug 21, 2017
1,894
RE:""If anyone has any leads or source or details or a better solution""
I am for that need (for car diagnostics) using just most cheapest Chinese (ebay) vibration meter (sorry, contact type but for 10 bucks only) what is showing the amplitude, acceleration, velocity and maximum spectra frequency. Thus to find out what is resonating at that frequency becomes very easy, and amplitude shows the severity of problem, alias mass of resonating detail.
38,816
A laser approach could measure vibration up and down but not side to side, so to get all vibration modes you would likely need three detectors orthogonal (XYZ) to each other.
