Measuring power factor of a single phase induction motor motor
LowQCab
Joined Nov 6, 2012
5,102
Or to put it another way ........
Use a 2-Channel Oscilloscope with one Channel showing Voltage, and one Channel showing Current.
38,819
Measuring current can be dangerous if the motor is powered from the mains.
A current transformer can be safely used for that.
The easiest way is to use a wattmeter such as the Kill-A-Watt.
It directly measures current, voltage, and power factor, as well as watts.
