I have a power supply built on veroboard. It's based off this design. The transformer is 36VCT. I would like to measure the voltage of both rails. I have two voltmeters like this.
As the schematic depicts, I attempted to measure the negative rail voltage by powering the meter off an lm7805 and connecting the Voltage sensing lead to the output of the lm337. This gives me the difference between the negative output and the unregulated DC negative input. How would I get the voltmeter to measure the difference between ground and the negative output?
I'm a lurker and this is my first time posting. I don't have much electronics knowledge. Is there any other information you would need?
Also, to improve current handling capacity, I tacked down 22 awg wire on the input and output strips.
