Measuring magnetic waveforms from coil
josh_TMS
Joined Feb 20, 2023
Hi all,
Looking to measure some magnetic waves being generated at an electric coil. Freq is between 0-20kHz and magnitude is pretty small <1T. Any have suggestions for the best tool to measure and log data of this magnetic waveform?
Googling around, I found meters like this: https://www.alphalabinc.com/product/mr3/
I thought maybe even a simple hall sensor but not sure.
What do you suggest?
Thanks!
Papabravo
Joined Feb 24, 2006
22,116
Hi all,
Thanks!
What measurement range will a simple sensor get you? Since magnetic induction is a vector, you will need three sensors, one for each component. Then you will need to compute the magnitude by knowing the magnitudes of the three components. Lastly you will need to compute the direction of the magnetic induction vector by using the magnitude and direction of the three components. This should be a piece of cake for a suitably robust DSP, once you identify an appropriate sensor.
Papabravo
Joined Feb 24, 2006
22,116
Here is a typical transfer characteristic:
Using the conversion factor of 1 Gauss = 1e-04 Tesla, a range of ±400 Gauss is equivalent to ±40 mT. This range may or may not be suitable for your purposes, but it seems rather limited to me.
grdunc
Joined Mar 27, 2023
Hi all,
Thanks!
A Hall effect sensor will work if the field strength and frequency is within the operation range. There are, or al least used to be, some giant mangetorestrictive devices. As I remember these will work from DC to the range you want but be sure to check the range and noise specifications.
Good Luck
