Measuring Current from 10pA to 100nA
farobin
Joined Jul 27, 2012
2
Hello Everyone,
I almost know nothing about circuit designing, apart from undergrad electronics. For the instrument I am designing
for Radiation Dosimetry application, I have to be able to detect light
with photo diode generating ~ 10pA to 100nA. Currently I am using Keithley
Multimeter. But my system has to be handheld. Could you please give me a
guideline how do I design a circuit to be able to detect this current range?
Any help will be highly appreciated.
takao21203
Joined Apr 28, 2012
3,702
Hello Everyone,
currents in this range are problematic to measure, because common EMI will induce such currents. Good shielding is essential.
Radiation detector based on photodiodes are possible and have been built, however they have noise problem vs. sensitivity.
Also these don't use small standard photodiodes, but special, large PIN diodes.
35,167
This should be my field of work but I would have to dig into the books to make it work.
Usually we would use a PMT. Any particular reason for using a photodiode, apart from portability?
farobin
Joined Jul 27, 2012
2
Thanks everyone for suggestions.
I would use PMT but HV required by PMT is a problem
for portability, and in the wavelength range 750nm, PMT sensitivity
falls rapidly. Infact for testing in the lab I used PMT, PD, CCD...but PD seems to be most user friendly for people and the cheapest.
I contacted with TI, but they also suggested about forums.
So kind of struggling to start with.
