Measuring AC Current & Voltage - LTSpice
Papabravo
Joined Feb 24, 2006
22,111
.meas TRAN acvolts RMS V(Vout)
.meas TRAN acamps RMS I(RL)
where TRAN tells which analysis you are interested in measuring, acvolts and acamps are "dummy names" for the results RMS is the function you want and V(Vout) and I(RL) are the things to be measured.
Other functions you could specify would be AVG, MAX, MIN, PP, INTEG. These measurements will be performed over the range of the abscissa unless further restricted by additional qualifiers.
Like this:
Results of the .meas statement are in the SPICE Error Log. The "dummy name" is replicated in all lower case in the error log and was pasted back into the schematic (.asc) file.
jp648
Joined Jun 12, 2023
9
Like this:
Thx Papabravo. I am seeing the values in the error log. Been messing around trying to get them to
display on the schematic but no luck so far.
J
Papabravo
Joined Feb 24, 2006
22,111
J
You can place a behavioral voltage or current source on the schematic and write an expression for the thing you want to display. Generally speaking, voltage sources are easier to work with than current sources. You could also create functional blocks (a .subckt) that would compute RMS values for you.
Audioguru again
Joined Oct 21, 2019
6,826
Your 20 number for "tran" showed too many waves. I changed it to 92 to clearly see if there is distortion.
On the left display I show the collector DC output with peak input and output voltages, 5dB per graticule.
On the right display I show the frequency response to 10kHz at the output.
jp648
Joined Jun 12, 2023
9
Thx AG.
jp648
Joined Jun 12, 2023
9
I have done a few hand calculations for the ac currents.
irl = Vout/Rl = 0.05297/10K = 5.30 μA
irc = (RL/RC) * irl = (10K/4.7K) * 5.3 μA = 11.27 μA
ic = irc + irl = 11.27 μA + 5.30 μA = 16.57 μA
ie = (ic/βac) * (βac+1)=(16.57/300)*(300+1)=16.63μA
ib = ie - ic = 16.63-16.57=6 μA
My irl agrees with Spice but my ic does not. Can you please tell me where I went wrong.
thx
J
jp648
Joined Jun 12, 2023
9
irl = Vout/RL = 0.05297/10K = 5.30 μA
thx
J
Correction. My irl agrees with Spice but my irc does not. Can you please tell me where I went wrong.
jp648
Joined Jun 12, 2023
9
Hand calculated irc does not agree with Spice.
Can someone please tell me where I went wrong with my calc?
Thx
Audioguru again
Joined Oct 21, 2019
6,826
Maybe the error is because the input signal source has a series resistance of 1k ohms which reduces the actual input to 8mV peak instead of 10mV peak.
jp648
Joined Jun 12, 2023
9
Maybe you could look at my calc and see where the problem is. The calc is based on the fact that there is an attenuation of
20% on the input voltage.
ericgibbs
Joined Jan 29, 2010
21,568
hi jp,
I did read your question, your problem could be due to the input impedance of the amplifier, especially when you had 1k source resistance.!
So much for trying to help you with LTSpice simulations.
E
The problem is simple enough.
Assume 1k source resistance and 4k Zin and a 10mV signal.
Attn = (1k/(1k+4k) *10mV = 2mV loss
