When I simulated a filter with a cutoff frequency around 200 kHz in LTspice, everything looked fine. However, when I tested it in the real world using a signal generator, I noticed that the signal amplitude dropped significantly right at the input of the filter.
Is there a special method or consideration for testing filters with such low cutoff frequencies?
