I need to measure the voltage between two electrodes EL1 & EL2 accurately and send it to a PC. Voltage between EL1 & EL2 can be +/-2V max. which I thought of using a Sigma Delta ADC. But EL1 and EL2 can be at a max. of +48V from Ground. I would be using Sigma Delta ADCs for the first time, and I got impressed with the high no. of bits in these ADCs at low prices! The accuracy required is better than 1mV. I am considering the following options.
1. Use 2 potential dividers and bring down the voltage by 10, to less than 5V, and measure them using 2 Sigma Delta ADCs and measure the difference. My concern is that these dividers would introduce additional inaccuracies, may be rendering it bad!
2. Use an isolated supply for the ADC and connect it to the uC using SPI and optocouplers. Speed requirement is a lowly 1 to 2 samples / sec.
Please comment on my choice and recommend any other better alternative. I might have to measure the voltage between an additional pair of electrodes, say EL3 & EL4 in the same setup, as a future requirement.
