Would all of the commercial True RMS voltmeters give me an accurate voltage reading of pink noise? In Table 6 of the datasheet for the AD737, optimum values for the averaging and filtering capacitors external to the chip are different relative to the waveforms to be measured. I was wondering if it would be worthwhile for me to construct an adapter such as Dick Cappels has done tailoring it for true RMS of (not sinusoidal) audio waveforms (my intended application), or if a commercial meter would be adequate for this.
https://www.analog.com/media/en/technical-documentation/data-sheets/AD737.pdf
Moderator edit: New thread created from this.
