Measure inductance of air core inductor
Marcodavid
Joined Aug 1, 2022
39
I am making an inductor
- Air core
- Wire: 18 AWG guage
- Turns: (I am not sure ) but could be about 6000 turns
- The weight of the wire : 400 gram
- The coil wrapped by machine
- Coil lenght is 5 cm
- Diameter of core is 1.5 cm
I used an inductance meter to measure the inductance and I got a weird reading of this large inductor = 3.7mH.
The DC resistance also is wire = 3.5 ohm.
Could these measurements be correct although it is a large inductor?
If so, how can I increase the inductance to 150mH?
Ian0
Joined Aug 7, 2020
13,306
Are you sure about 6000 turns? There seems to be about 50 on a layer, and probably not more than 10 layers.
38,909
Yes. probably.
It may be large physically, but air core inductors have a much smaller inductance for a given number of turns compared to one with a magnetic core (iron, ferrite, etc.).
Here's a picture of a 3.5mH, 18 AWG air core inductor to show the relative size.
So you need a much larger coil.
Why do yo want such a large air-core inductor?
28,485
Consider that the capacitive reactance of allthose turns in close proximity tends to cancel the inductive reactance. This is an unfortunate reality. So now comes the question about "what is the application for the inductance?"
