Measure a voltage larger than operated voltage of a comparator
terrylai
Joined Oct 11, 2022
7
Hello all,
Recently I am doing project of measuring temperature. The target is a battery operated device. I need to use a comparator to measure supply voltage and sends out a warning LED signal to users if the supply voltage is lower than 3V. The comparator is from the MCU which is operated in 3.3V by four AA batteries (6V) using DC-DC converter. I want to ask would the MCU burn if the 3.3V operated comparator measures the supply voltage which is more than 3.3V (for example 5V). Thanks!
BR,
Terry
DickCappels
Joined Aug 21, 2008
10,661
Check the data sheet for the comparator, it is almost certain to say that the input cannot exceed the power supply. This specification is usually referred to as common mode input voltage range.
It may also be listed under Absolute Maximum Limits.
Jerry-Hat-Trick
Joined Aug 31, 2022
866
I’m not sure I understand the problem exactly, but could you use the MCU to measure the supply voltage by using a potential divider with two equal value resistors where the central tap is read by an A/D pin of the MCU which would work for a supply voltage up to 6.6V?
If the supply voltage could go higher, adjust the resistor values so the MCU input never goes above 3.3V
Ian0
Joined Aug 7, 2020
13,317
Does your DC-DC converter have a pair of resistors which which feed back a proportion of the output to the control circuit? If so, that would be a convenient point to connect to the A/D or comparator input.
Papabravo
Joined Feb 24, 2006
22,116
It is possible to make a device that WILL tolerate input voltages that are higher than the supply voltage. If that is the case, it will be explicitly stated in the datasheet. It is always safe to make an input voltage be within the stated limits by any means available.
BobaMosfet
Joined Jul 1, 2009
2,211
Hello all,
BR,
Terry
Learn about voltage dividers (you can scale voltages this way, into a range you can manage).
Title: Understanding Basic Electronics, 1st Ed.
Publisher: The American Radio Relay League
ISBN: 0-87259-398-3
