Meaning of Rds(on)
jaydnul
Joined Apr 2, 2015
175
Really!?
Then according to the math, in triode mode: \(r_{ds}=\frac{1}{2k(V_{gs}-V_{th})^2\), let's say \((V_{gs}-V_{th})=5V\).
Then the FET's k value to get an rds value of, say, .01 ohms is:
\(k=2 \frac{A}{V^2}\).
Is that right?
38,631
Can anybody address post #18?
The definition of saturation is different between a BJT and a FET (just to confuse us all).
Saturation for the BJT means it is fully on with low resistance as a switch.
Saturation for a FET means it is in the high impedance (constant-current or triode) part of its operation where the current is proportional to Vgs.
When a FET is fully on with low resistance Rds it is in the Linear Region not the Saturation Region.
Papabravo
Joined Feb 24, 2006
22,099
Now that I think about it, that is correct, and I did have the terms saturation and linear mode reversed. The characteristic curve is quadratic from Vgs≥Vth up to Vgs≤Vgs(on) and it becomes linear after that.
Jony130
Joined Feb 17, 2009
5,598
MikeML's plot illustrates my question just fine. When the gate voltage is 5V, Vd is fractions of a volt. The math says this should be a FET in triode mode, Vgs-Vth>Vds.
Yes, transistor is in triode mode.
Triode mode = full ON MOSFET and Id = Vdd/(Rd + rds(on)) ≈ 40V/10Ω ≈ 4A
So what you do not understand here ?
ian field
Joined Oct 27, 2012
6,536
You are assuming that all of the device can operate at all of its maximum parametric values at the same time. It cannot. The part has a max voltage, a max current, and a min resistance, but not all at the same time. So if it is rated for 100 V and 10 A, that does not mean that it can operate with 100 V Vds and 10 A Id at the same time. That would be 1000 W power dissipation in the device, and it would fail almost instantly. If the part is rated for 100 W, then when it has 100 V across it it can sink only 1 A before exceeding its thermal rating. Or it can sink 10 A, but only if Vds is less than 10 V. Voltage, current, and power are the three limits that must not be exceeded.
ak
The term you're looking for is SOA (safe operating area).
