What is the meaning of resistor R1?
Jony130
Joined Feb 17, 2009
5,601
It is a pull-up resistor, its job is to ensure that T1 will be OFF when you power the circuit.
And is some cases T1 will also need a pull-down resistor.
Jopee
Joined Jun 30, 2024
41
But If I remove R1 then transistor has 9 volts at emitter and base? So transistor should be OFF? But for some reason it is ON when I connect battery.
Jony130
Joined Feb 17, 2009
5,601
But can you define the value of a base voltage in this case? The base is "floating".
So the base voltage is not well defined in this case, and this is why we are adding R1 resistor.
ericgibbs
Joined Jan 29, 2010
21,623
Hi Jop.
R1 as you have it connected between the emitter and base of a PNP transistor is effectively a pull down resistor.
So that in order to turn on T2 sufficient current, or greater has to flow through R3 to generate 0.65V.
That is I= 0.65/10k =65uA.
This should only happen when SW1 is pressed.
Without R1, any leakage current through T1 and R3 will be sufficient to turn On T2 and make T1 conduct and turn On the LED.
E
