Okeey....just to clarify the things..
I'm using the pin 0 & 1 to send the commands to the device okey and that's the setup for that :
Code:byte POLL_ADDRESS[3]{0x0B, 0x33, 0x12}; byte EXT_UART_BUFFER[37]; //incoming buffer for receive data from VMC struct MDB_Byte MDB_BUFFER[37]; //incoming buffer for receive data from MDB peripheral int EXT_UART_BUFFER_COUNT; volatile int MDB_BUFFER_COUNT; //MDB receiving flags int rcvcomplete; //MDB message receive completed flag int mdboverflow; //MDB message receive error flag void MDB_Setup() { // Set baud rate with setbaud.h UBRR0H = UBRRH_VALUE; UBRR0L = UBRRL_VALUE; // Disable USART rate doubler (arduino bootloader leaves it enabled...) UCSR0A &= ~(1 << U2X0); // Set 9600-9-N-1 UART mode UCSR0C = (0<<UMSEL01)|(0<<UMSEL00)|(0<<UPM01)|(0<<UPM00)|(0<<USBS0)|(1<<UCSZ01)|(1<<UCSZ00); UCSR0B |= (1<<UCSZ02); // 9bit // Enable rx/tx UCSR0B |= (1<<RXEN0)|(1<<TXEN0); }
In other hand the cashless can get mycommands correctly and reacts like it should be. When I want to read the poll responses from the device and using the SoftwareSerial I m forced to use other pins okeey (10 and 11 for example ).
But in this case I have already attached the UART device pins in 0 and 1, how can I get the responses on the pins 10 and 11 ?
Hi, I am trying to communicate with mdb with similar hardware. I wonder if you were able to solve your problems?
Mod:New thread, link to old,
https://forum.allaboutcircuits.com/...verything-else-works-fine.197954/post-1911530
