MCP4725A1 stop working
far95
Joined Oct 13, 2021
Hello Guys , I'm using DAC MCP4725A1 before it works fine but suddenly it stop generate sinusoidal signal it generate 2V.
I'm using it with atmega328p to generate periodic signal 5V.
This is the schematic
trebla
Joined Jun 29, 2019
599
Nothing wrong with the schematic, so probably the problem is in software. If you suspect the DAC is damaged, try to replace it.
