MC34063 darlington out
alimutlu1
Joined Aug 4, 2017
23
I was trying to design a low power forward converter which convert 5V to 3v3. I used mc34063 for PWM at 100khz. But in datasheet the saturation voltage typical 1V, max 1.3V for output of 34063. ( it has two transistor as configure darlington in output). Therefore the number of two in transformer can not go zero. 34063 can not push it to ground.(In the photo blue waveform-probe 2). I need to create %50 duty cycle in 100khz. Can anybody help to me ?
AnalogKid
Joined Aug 1, 2013
12,263
That looks like a massive amount of work to go through just to drive a linear regulator at the output.
1. Is an isolated output required?
2. What is the required output current?
ak
