I recently salvaged a mc34063 from a damaged car charger. I experimented with various configurations. I currently have it set up with an external npn. The resistors that attatch to pin 5 dont seem to be changing the output voltage. The only thing that does is when i change the resistor that goes from 2 to ground. I can post the exact component values later today, but i know offhand that im using a 220 uh inductor and thrle resistors on pin 5 are configured for 5 volts (1000 and 3300 ohms) but it usually reads about 3 to 4 or 6.5 to 7.3 volts. Any ideas?
