All, seems there are lots of versions of this board and no high res photos where I can make out the value of R22.
Thanks, saw that on the diagram but was not sure. I'll order one now!1K !
Would you mind sharing the value of that C2 capacitor. Mine is toasted and can't see the numbers.All, seems there are lots of versions of this board and no high res photos where I can make out the value of R22.
Max, do you by chance have the value of that C2 capacitor on the lts-50?What is the part No. of the board?
I don't , can you post a pic?Max, do you by chance have the value of that C2 capacitor on the lts-50?
Thanks.
Sam.
Okay,If it is connected across pin 1 & 2 of the G5551 then other boards that use the same IC use a 221K = 220pf
Do you know the voltage that should have?Okay,
Thanks for the info, I'll give it a try.
MC2100LTS-50W REV B troubleshooting | Technical Repair | 1 | ||
F | Help with MC2100LTS-30 | Technical Repair | 4 | |
E | Motor Controller Formerly Known as MC2100LTS-30 266333 or 398057 | Datasheets, Manuals & Parts Identification | 0 | |
S | MC2100LTS-30 | Technical Repair | 6 | |
T | Mc2100lts-30 that took 240V | Technical Repair | 7 |
