All, seems there are lots of versions of this board and no high res photos where I can make out the value of R22.
Thanks, saw that on the diagram but was not sure. I'll order one now!1K !
Would you mind sharing the value of that C2 capacitor. Mine is toasted and can't see the numbers.All, seems there are lots of versions of this board and no high res photos where I can make out the value of R22.
Max, do you by chance have the value of that C2 capacitor on the lts-50?What is the part No. of the board?
I don't , can you post a pic?Max, do you by chance have the value of that C2 capacitor on the lts-50?
Thanks.
Sam.
Okay,If it is connected across pin 1 & 2 of the G5551 then other boards that use the same IC use a 221K = 220pf
Do you know the voltage that should have?Okay,
Thanks for the info, I'll give it a try.
MC2100E rev c icon 2003 | Technical Repair | 8 | |
| L | Preparation for semiconductor testing course admission test | Jobs & Career Advising | 0 | |
| B | Lexicon Pcm41 repair | Technical Repair | 8 | |
| J | MC2100LS-30 REV for replacing an old MC2100LTS-30 | Technical Repair | 1 |
