Hi All, I have a Nordic Track T25 treadmill, my gf said she heard a popping noise yesterday when she was using it, then it just stopped. I don’t mind purchasing a new controller but I would much prefer trace the faulty components and learn how they work and why they failed and if course if it was ever to happen again I would know what to look for, any help would be greatly appreciated!
When you switch the treadmill on the red led on th controller comes on for about 5 seconds then goes off, the display does not illuminate when the power is switched on, I believe the display needs 9-12 volts, I’ve tested the red and black going to the display and there’s nothing.
Ive inspected the board closely and I have noticed there is a blown component but because of the damage I can only see a partial part number, it’s STR G6??? When I find out what the correct replacement is would I just need to replace that part or do I need to carry out tests in I case there are other faulty components that caused it to blow?
