MC2100ELS-18W
SPERRIN1
Joined Nov 2, 2021
1
I HAVE MOTOR CONTROLLER MC2100-18W WITH C31 BURNED UP DOES
ANYONE HAVE THE VALUE OF C31 AND A CLOSE UP DIAGRAM OF THE PRINT.
BERNARD
30,772
There is a reverse engineered version of the MC2100 here if you do a search.
I may have a 18W ver here, if so will post the value.
Can you take a pic of the boards showing the C31 location?
galwayg
Joined Apr 17, 2023
5
Hi, I have the same issue here. C31 was burnt and causing a short on the board. I have removed it and it is no longer short. When powered on without C31 on the board the led blinks 8 times. Does anyone know if replacing c31 will solve this? If so does anyone know the value of c31? I'm thinking 10uf but unsure of v.
Thanks in advance.
30,772
The model I have which has a C31 is on a version that uses a SMPS for the 12vdc.
C31 has 2229 on it where tha value normally is, not sure of what the 9 signifies.
It appears to be a ceramic or even a Tantalum.
As a last resort, you could add a normal linear supply as most of the other model versions do.
galwayg
Joined Apr 17, 2023
5
Thank you for the info! Very much appreciated
Would it be possible for you to post a picture of it?
