MC2100 Rev B - Issues (Treadmill Main Board)
30,885
Greetings, electronic community, I have problems with icon fitness's mc2100 lt boards, since the board turns on, it works, inclination, but the motor does not, before this, I see publications that changed the mosfet, the scr resistors and they do not remain. In this case, it is similar who has been able to find the cause in this board turns on the board the motor rotates but it is not correct input voltage there is no motor output voltage when you give it speed the Led turns on 5 times turns off turns on 5 and in that motor cycle it consumes with a 12 v battery .45 mamp in series with a multimeter Does anyone know the number of main parts?
of this board and in the pwm controller which is the negative
Please translate before posting! o_O
What version of the board is it? post a full picture.
30,885
The 5 blink pattern is the console controller cannot resolve a motor rpm issue.
This is most likely to be one of the devices fitted to the heatsink, also check to see if the DC to the Mosfet ramps up when a command is issued.
