- Joined Jul 18, 2013
- 30,828
20Hz was originally recorded from the console output, and the only one that will work in this range.
Any simulator uses this freq.
Thanks, I've checked it under my microscope, but can't find anything. Also not this board is conformal coating, so it's not so simple to access all the components.The board don't have some soldering lose In some component or area?
Don't have any lose of tracks?
Do you have something which show a big photo of the board to look?, like microscope etc?
If it does quit, see what the red LED rate is !I bet if I close the enclosure within a few days it will start failing.
If not, I don't know... it must be something related to the connector that now disappeared. Strange issue.
