Hi All,
first post so please be gentle. I have a treadmill. Proform 525EX manufactured by ICON. It was left in house I recently moved to. Non-running so I investigated as to why. Power gets to the treadmill fine. The safety key works as the incline works and then stops when the safety key is removed. However the belt won't run. On further investigation I found the speed controller shot. The board had a label which says MC-66 but the actual board is a MC-65. I trawled the net and found a few threads on these boards but they don't answer my questions. I've been trying to find a schematic with no luck. Although some of the construction is similar to the MC-60 which help me construct the part schematic I have attached of the power section.
There were a couple of components physically blown ( the S8020L, D8020L and one of the 470uf Caps) which I replaced. When I power the board now I don't get any LED's lit. I've tested the LED's and all appear OK apart from the SCR TRIG which fell apart when I was testing it. So questions are:
It's a long time since my college days of working electronics so I'm a tad rusty but can remember a lot of the theory so any pointers would be massively helpful.
Thanks in advance
Paul
- Where can I source a replacement LED as I don't know the value or part number?
- When the board is connected I can't find 12v anywhere on the board. From the schematic should I be seeing 12v around Zener D3?
- When testing for the 12v what should I be testing too? GRD or AC1/AC2?
Thanks in advance
Paul
