There's no need to be rude! I know this IC quite well, I have stocked them for years for use on projects and have made many successful SMPS power supplies using this IC....Also it is wrong. The current limit exists to limit the output current, not to increase efficiency, or as a mandatory means.
If you regulate voltage you don't clip off the current peaks. This is science fiction.
I think from his website, RB should know much better.
If you want to ignore my advice and keep guessing that you have "bad clone ICs" or something that's fine, but I will tell you again the current sense resistor is an important part of the circuit and needed to be properly set up to limit the peak current through the inductor, and it also affects oscillation frequency and efficiency in a big way.
If you are asking for help with an IC you might want to listen to advice from people who know the IC much better than you do. You won't be getting any more advice from me because I think your attitude stinks.
