maytag LAT* water solenoids
Poor old sod
Joined Jul 25, 2017
154
are they 240vac? washer mech/elect only, no digital. is spray rinse essential? project: install 12v4A auto stop bilge pump to return rinse water to tub [>40L] by installing locking cct to change power from cold solenoid to pump when motor starts asynch speed. might need auto drain [retic?] valves to empty wash cycle after pump stops. advice pls. splice washer drain pipe easy. can use splice to/from tub with tee. washer and laundry tub same height and adjacent, tub > 100L, washer 70L max. maytag have fast drain pumps. can use end synch motor action to trigger drain valves, reset with end asynch motor run.
