Maximum Vds Reverse Voltage Applied on a MOSFET
denismoreno
Joined Apr 24, 2022
I want to design a back to back MOSFET circuit. If I simplify it, it look like this:
I'd like to know what is the maximum voltage I can apply on bothe transistors. I ask specifically what are the voltages of the transistors I choose. Does the voltage divides evenly when they are both close so I can take a transistor with lower vds?
Thank you.
Irving
Joined Jan 30, 2016
5,195
Why do you need this to be bidirectional? What is M2 doing for you? In this circuit M2's internal drain-source diode is forward biassed if M2 is off, so M1 sees -(Vdd - 0.5v) approx Vds.
BobTPH
Joined Jun 5, 2013
11,609
The voltage does not divide evenly, one of them is always acting as a forward biased diode dropping less than a volt.
Bob
