In a previous reply I recommended an LM6181. While this is a reasonable IC for use on a +/-15 volt power supply, it may not work very well on +/-5 volts.
The LM6181 output swing will not be very good -- only about 4 volts p-p. It would be nice if the amplifier had a rail-to-rail output that can drive 100 ohms while running from +/-5 volts of supply. I found some but they are _not_ in through-hole packages.
The closest I found with a very quick search is an AD8036. The AD8036 also has the advantage that it is a voltage feedback op-amp. (The LM6181 is a current feedback op-amp). If you don't mind a SO-8 packaged IC then the ADA4817-1 is real nice but pricey.
