mastercraft 2.5a corded oscillating not power on
LAOADAM
Joined Nov 21, 2018
956
ThePanMan
Joined Mar 13, 2020
950
The control board is potted, so chances are there are no (quote: user serviceable parts).
An overall picture would be useful. Both C & D are black wires, which suggests they may be common to one and other. I see a red wire as well. Do you get any voltage between the red and one or the other black wires?
LAOADAM
Joined Nov 21, 2018
956
Thanks.
there are just 4 wires. there other 2 blacks for switch; and other 3 colour wires for speed adjuest pot.
all other wires breach out from C/D for brushes etc.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Bit late for this one, but a future alternative is Princess Auto, (No Sale is Final Until You are Satisfied). :cool:
They have always honored it for me!. ;)
28,238
REally, the module would be repairable if it had not been encapsulated to make it non-repairable. If it is supposed to be providing 24 volts DC for the motor, the service procedure will be to measure the motor voltage. The other possible problem could be the variable speed control. That can be checked with the power feed disconnected.
MaxHeadRoom
Joined Jul 18, 2013
30,808
No doubt uses a Universal (AC/DC) motor.
If that is a 120v Triac controller, then it would be simple to replace it, with test running the motor on 24vd and it runs slow, the motor is probably OK.
28,238
Once again, the one part that could be checked and replaced is the external speed control variable resistor. So that needs to be checked using an ohm meter, with the device disconnected from the mains.
Then also, if that circuit board is coated with tar, it can be cleaned off and repaired fairly easily. A tar coating would be black and able to be melted, or removed with a common solvent, even gasoline. Certainly that requires a great deal of caution and should only be done by one familiar with the needed precautions.
But it seems that the TS mentioned brushes. So the motor may be either a universal type, or more likely a permanent magnet DC motor. For that determination we need more information.
If the TS has a multimeter then a great deal can be learned, if not, then only guesses will be made.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Personally I would see if the power IC showing can be removed, appears to be a Triac?
If defective,, might even be possible to replace it by cleaning the leads coming out of the potting. ;)
Also the three speed control leads appear to exit at the bottom of the enclosure.
28,238
Consider that a damaged or failed speed control could be the cause of the inability to run at a higher seed, testing that control seems very much a good choice the. And if the material covering the PCB is a tar type of material then it can be removed so that other components could be replaced.
MaxHeadRoom
Joined Jul 18, 2013
30,808
The way I read it, the running at slow speed was due to the OP using 24vdc on the motor leads to test, if so obviously that will be the result!?
"Oscillating Multi-Tool"
28,238
The fact that the motor does run at 24volts DC does tell me that probably the motor is OK.
Otherwise, one option worth considering would be to bypass the module completely, wire the switch in line with the power cord directly to the motor, and use an external speed controller. like those available for controlling drill motors.
MaxHeadRoom
Joined Jul 18, 2013
30,808
As per #8, if the semi can be removed and identifies, should be easy to replace if that is the problem, also clarify if Triac control.
I imagine they would use mechanical reversing for the oscillations.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
sure I have a multimeter. just don't know what to do to measure?
BTW. I bought another. so this one can do any thing on it, even tear it down.
LAOADAM
Joined Nov 21, 2018
956
good. I'll try from here.
LAOADAM
Joined Nov 21, 2018
956
I'll check it.
