Converting 14.4v cordless drill to corded.
Bassquake
Joined Feb 16, 2018
97
I have a variable speed (by trigger) 14.4v cordless drill but the nicad batteries are going.
Have tried "zapping" them but didn't work.
I have a choice of DC adaptors to use:
  • 12v 4A
  • 15v 2A
  • 18v 2A
Which would be good to use? Unfortunately I don't know what the amp rating is for the drill but looking at others it looks like 2A is common.
Bassquake
Joined Feb 16, 2018
97
P.S. Test the drill on an automotive battery, place a typical load and measure the current.
Max.
I don't have a car battery or power test bench to test with. Can I use my multimeters amp setting and test the amps used with the drills battery? I realise the battery wont give a proper reading but itll provide a start?
Bassquake
Joined Feb 16, 2018
97
MaxHeadRoom
Joined Jul 18, 2013
30,885
That is possible for a motor that runs almost 20krpm!
Although if more than a second or so, would burn out the motor.
This is why if you could find access to a automotive battery and make some tests, would be a little more conclusive.
Max.
be80be
Joined Jul 5, 2008
2,398
Dont test it with your multimeter you'll blow the fuse maybe even something burn up
The drill would need a supply around 10 amps it never stall. It's geared down I don't think you could hold it to stall the motor. most people let go long before that happens.
Bassquake
Joined Feb 16, 2018
97
Bassquake
Joined Feb 16, 2018
97
Its been a while, but I bought that power convertor and made an enclosure for it. Added a slow burn 10A fuse to the output as suggested by MaxHeadRoom. Seems to work fine!
Something to do while in lockdown!
Edit: Add another pic.
