I'm trying to repair a Makita DMR110N for a friend. It originally did not turn on. It was dropped from a reasonable height and failed. When I got it apart, a transistor had blown up. The same transistor as had blown in this link:
https://maker.pro/forums/threads/replace-blown-component-makita-radio-dmr104.293953/
Which is a 2SB1143.
I swapped this out for a new one, and the device now powers up and operates correctly visually (all buttons work etc) however there's absolutely no sound whatsoever so I'm guessing something downstream has died. You can hear that the speakers seem to be receiving a small amount power as there's a very very faint amount of noise which is common with powered radios, amps etc, but no matter whether I use aux, or dab radio, or FM, there's absolutely no sound whatsoever.
I've attached some images that show the component which I've replaced and also the rest of the PCB's. Are there any known failure points? I've reflowed the ET2314 which is a digital audio input processor and also what appears to be the amp chips solder connections, but this has made no difference as of yet.
Any suggestions? I was thinking of replacing the ET2314 but it feels like I'm just guessing at this point. How would I best diagnose it?
I've uploaded some photos:
This is the transistor I've replaced, the same as the one identified in the other thread.
Reflowed the below, the ET2314 and the Amp chip but to no avail...
Which is a 2SB1143.
