Makita charger
Bigkev75
Joined Sep 2, 2023
Hi peeps,
Not sure if this is ok but i need help fixing my makita twin charger i know there are a few wizards out there when it comes to electronics, one side works ok but the other side is not working i have power from the supply to the circuit board there is a slow blow fuse this has no continuity so i think its blown i did rest a 3amp house fuse on top of the 4amp slow blow fuse and turned the power on and it went pop straight awayScreenshot_20230902_163942_Gallery.jpgScreenshot_20230902_163927_Gallery.jpgScreenshot_20230902_163759_Gallery.jpgScreenshot_20230902_163837_Gallery.jpg
Dodgydave
Joined Jun 22, 2012
11,395
Check the Mosfet and bridge rectifier for shorts,.
With the power off, on Ohms put your meter across the+/- terminals of the bridge rectifier, it should read around 200 ohms or above, check the Mosfet on diode function, across the D/S (middle and right terminals) and it should read open circuit one way and 650mV the other way.
Bigkev75
Joined Sep 2, 2023
Thanks buddy , which pins of the 3 on the bridge rectify are + and - ? I tested the mosfet and got 0.500 v and OL 16936812024571121199875368368168.jpg
Dodgydave
Joined Jun 22, 2012
11,395
The outer two terminals are+/-, but you can check also on diode test across the centre pins and +/-, it should read open one way and 650mV the other way.
