Making small sparks
cmartinez
Joined Jan 17, 2007
8,887
Now you have thrown a XY axis into the mix, :) This usually is a requirement of wire EDM, I would think sinkers are predominantly Z axis move only?
Although the XY would definitely make it more flexible.
Max.
The sinker circuit I posted was intended as an example on how to generate the power needed for the EDM to work and the logic behind its functionality... If I'm going to venture into a project like this one, I'm going to aim for an XY plus 2-axis tilt control... effectively a 4-axis machine. ;)
MaxHeadRoom
Joined Jul 18, 2013
30,881
Ambitious project! I have done a lot of work with PC slot based motion cards (as well as stand alone) such as Galil and may look into using one of these as a EDM controller.
Max.
cmartinez
Joined Jan 17, 2007
8,887
Max.
I've already designed my own controller capable of managing up to 8-axes. Unfortunately, it only does linear interpolation and doesn't have routing capabilities... just yet. For that I use Indexer LPT, for which I wrote a code generator a long time ago that works within AutoCAD.
shortbus
Joined Sep 30, 2009
10,049
When still working they bought a few (3) of the latest Charmilles CNC EDMs. They tried to do a job using an X axis move, to make an undercut like a mill table "T" slot in a part. What a mess! There is so much electrode wear that it took for ever to get it done. This was to one and only time they tried it, at least while I was working in the department.
