Making oscillator using zener diode
idrbur
Joined Jan 11, 2018
70
I was wondering if i can use an zener diode instead of a transistor to make that single transistor oscillator cause basically it works on breakdown of the emitter. Or making a Pierson anson oscillator using zener diode instead of neon lamp.
Any suggestions?
38,819
A neon lamp can be used in an oscillator circuit because its breakdown voltage is higher than it's sustaining voltage (negative resistance).
A zener has its breakdown voltage the same as its sustaining voltage, so won't work in a oscillator circuit.
