making booster to 12 vdc 4A
smsebna
Joined Feb 13, 2020
Hello every one!
I have RGB strip led and i should use 2 batteries of 18650 (Li-ion) to turn it on. this strip have 12vdc and maximum current is 4A.
I want to build/buy a booster that Vin=3.7v dc or 7.4v dc (2 batteries of 18650 in parallel or series), Vout=12 v dc , Iout=3-4A.
I will glad to hear your comments
Papabravo
Joined Feb 24, 2006
22,116
Hello every one!
Read very carefully and learn something
  1. 12 VDC x 4 Amperes = 48 Watts of Output Power
  2. Any conversion scheme you use will be less than 100% efficient
  3. Let us assume it came from an undisclosed country and is 80% efficient
  4. 48 Watts / 0.80 = 60 Watts of Required Input Power
  5. 60 Watts of Input Power @ 3.7 VDC ≈ 16.2 Amperes
  6. It gets worse as the battery discharges, @2.8 VDC, it requires 21.4 Amperes
  7. Your battery would need something like 100 Amp-Hours to keep the strip lighted all night
  8. Do you still think this is a good way to go?
smsebna
Joined Feb 13, 2020
thank you,
I must use 4 batteries in series to obtain 2.5A at input
