Make voltage rails/terminals in LTspice ?
DarthVolta
Joined Jan 27, 2015
521
I didn't see it in 2 basic pdf's so far. How do make a node, a terminal, that I can then place anywhere else needed, rather than running a wire, you know what I mean.
38,617
Anyone know what LT calls their negative regulators like 79xx ?
LTspice mainly only includes Linear Technology (and now Analog Devices) parts, so for other parts you may have to find a model for it and import to LTspice.
Here are some Linear Technology negative linear regulators that should be in LTspice.
DarthVolta
Joined Jan 27, 2015
521
good, I've almost fully taken apart a full 335W computer PSU, and measured the cap's, inductors, and zeners. Now I've just found a LT1241 PWM controler, which is basically the same as the 1 in this.
For now I'm just using stand-in voltages for the various windings., getting a feel for what to expect, and not expect. Then when I put it back together it will make a lot more sense to look at on the scope.
