Make a USB charge point from DC input
Vindhyachal Takniki
Joined Nov 3, 2014
598
I have to make dc charge input from two options below, so that any mobile or related device can be charged:
1. Input: 17.5V-29.4Vdc
Output : 5V/1A for USB charging
Led: Led indication when mobile is plugged in i.e charging occurring
Led off when charging completes or nothing is plugged in
2. Input: 7.5V-12.6Vdc
Output : 5V/500mA for USB charging
Since I need low cost option, so I am planning to use LM2576 option for both of them.
Lowest I think would be LM7805, but it gets heated up evn in case of 12.6V & 500mA option also. Since it produces wattage of around :
(12.6V-5V)*0.5 = 2.55W
So I am not using this.
1. Is there any other low cost solution which can be used, in which inductor is not be used externally. Dont want to use it since not availble in low cost option in local market.
2. I also want to limit the current to 500mA & 1A so that any device should not be able to draw more current. What should I do in this case? What is recommended use for this. Or let the load draw more current in case of error/overload, LM2576 will thermal shutdown in case of over-temperature.
3. Led indication when charging happens i.e when current is flowing. Should I place a current sense & place a op-amp across it & make a led glow or any other option also available?
wayneh
Joined Sep 9, 2010
18,167
That much is easy. I'd use a comparator instead of an op-amp, but the idea is the same. A low ohms shunt resistor causes enough voltage above ground to trigger the comparator. I've used a LM393 quad comparator for this and even used two different levels: One LED to indicate a device was connected, charging or not, and another to indicate when the current was above some threshold. If you really wanted to go crazy, you could use the LM3915 to visually indicate charging current over a wide range.
tcmtech
Joined Nov 4, 2013
2,867
Most any decent quality USB car charger adapter will work on a ~8 - 30 VDC input with input voltage wiggle room above and below that as well.
