Make a counter help
merhaba28
Joined Jun 8, 2020
Hi. I want to make a counter. firstly 0-4-6-8-12-14 and add to waiting block (delay) for 3 minutes. Secondly counter count to 0-1-2-3-4-5-6-7-8-9-10-11-12-13-14-15 counter is finish.
merhaba28
Joined Jun 8, 2020
Sorry. I designed the first part. but I don't know how to add the wait block and the second part.
AnalogKid
Joined Aug 1, 2013
12,126
1. Why is this an emergency?
2. Please post a schematic of what you have done so far.
3. Is this homework / school work / class project?
4. Are you talking about one counter going through two different sequences, or two separate counter circuits with a timer circuit in between?
5. What is the clock source for the counter(s)?
ak
schmitt trigger
Joined Jul 12, 2010
2,087
The second part is the easiest, as it is a 4 bit binary counter, for which both TTL and CMOS ICs are available off the shelf.
If you were able to desigh the very first section, which requires gating to select an non-natural counting sequence, the second counter should be trivial.
dl324
Joined Mar 30, 2015
18,326
