Magnetic design and simulation software, the free kind
DickCappels
Joined Aug 21, 2008
10,187
Does anybody know of a more or less free magnetic design and simulation software package? This would involve both static and AC fields.
DickCappels
Joined Aug 21, 2008
10,187
Thank you all of these excellent recommendations. I see a steep learning curve ahead, and that is to be expected for something like this. Thanks again!
sparky 1
Joined Nov 3, 2018
759
Fasten the object with magnetism to a rotary table centered half the height of the Z axis.
A hall sensor is fitted to a stepper driven Z axis calibrated high and low for flux density.
As the table turns one complete rotation it samples 360 times then it drops 1/10 of an inch and repeats until complete.
A set of 360 readings having 3 elements each revolution is read into a file and saved. ( Strength, Angle, Z_height )
Choose an open source 3D model software. (draw a simple example and decipher the file. (learning curve))
Convert data called Strength to correspond to a color, open the file in the modeling software.
Sorry about the over simplification.
