Magnetic coil Frequency
28,243
Measure the resistance, because that is a small coil without much inductance, unless the description just neglected to mention the details, which we have none. I=E/R
Not a word about the construction, core, number of turns, or wire size.
uppi_777
Joined Feb 26, 2018
70
Number of turns is 12
28,243
OK, so the length of the wire is 12 x 4 x 1.8 meters. And now the assumption is that there is no magnetic material in the core. So while there are formulas for predicting the inductance, I do not have them handy, other than to predict that the inductive reactance at 60H will be quite low, and not affect the current much. The wire resistance per length is published in tables for many wire sizes, and as we do not know the wire size the TS will need to look that up.
The calculations for the flux density are posted, so that can be calculated. The current will be close to what is predicted by the supply voltage and the 60 Hz frequency for the calculated resistance, which depends on the wire size. At 60 Hz the inductive reactance will not be significant. The current will be limited by the resistance.
I am not sure what the "30A/ M tells me, unless that is the intended current density.
That whole process should be obvious to a design engineer.
And this looks a whole lot like homework for one who was not paying attention in class.
Janis59
Joined Aug 21, 2017
1,894
Resistance is nothing to do when in AC. In DC yes, then i=V/R. But in AC the X(L)>>R thus the i=V/X(L) where x(L)=2pi()fL. If want very exact, may add the active component by Pythagorus: Z=sqrt(X(L)^2+R^2). But R and X ratio rather sharp differs by moving the core in and out, thus the most exact method is to measure. LATR+Ammeter+Vmeter+magnet. What is permissible current may dedicate seeing the wire diameter. A=pi()r^2/4 and permissibl;e is 2 A/mm2 when bibbin is perfctly cool, and 3...3.5 A/mm2 when it is hot on the edge, and up to 5 A/mm2 for rare short applications like lock unlocking. One minute work and one hour to cool.
28,243
Did you calculate the inductive reactance of that coil at 60 Hz??? The TS was not asking for an exact answer, based on the lack of information provided.
28,243
OK, my approximation says that is 288 feet of wire, 12 turns of 24 ft each and if the wire is #16, reasonable for 5 amps, and about 4 ohms per thousand feet, then the resistance will be a bit over ONE ohm. So the inductance of that coil must be a fair amount.
Danko
Joined Nov 22, 2017
2,236
by using the above formula and inserting x=12 a=1.8 and b=1.8 but still i was not able to get the answer 60
x is location from the center of the loop (the centre is located at point x = 0),
so we use x=0.
i also inserted by using x=0
Double check your calculation. With x=0 answer should be 60.
This answer is for one turn (loop).
For 12 turns we should divide answer by 12.
So, I=60/12=5A
ADDED:
Formula for Excel:
=30/((2/PI())*(1.8*1.8/SQRT(1.8*1.8+1.8*1.8))*(1/(1.8*1.8)+1/(1.8*1.8)))
Answer:
59.9789196651...
