macro and preprocessor in C
@vajra
Joined May 2, 2018
154
I am having trouble to understand difference between macro and preprocessor directives in C,
What is the difference between them? seems like they are more or less the same? I tried to look up on the internet, but still can not understand it, can anyone help?
Papabravo
Joined Feb 24, 2006
22,116
The macro, or text substitution capability, is confined to the operation of #define. All of the other preprocessor directives and #define operate in a processing step that happens BEFORE the compiler sees the input text. You start with your input text, it goes through the preprocessor, and from there it goes to pass 1 of the compiler. From there it depends on the compiler how many additional passes are performed.
@vajra
Joined May 2, 2018
154
The preprocessor runs before the compiler.
I found the page https://en.wikiversity.org/wiki/C/Preprocessors Example in page is incomplete
#if - #else - #endif
Header.h file
Code:
#define MAX_VALUE 10
#if (MAX_VALUE == 10)
printf("Correct max value");
#else
printf("Incorrect max value");
#endif
sample.c
Code:
#include<stdio.h>
#include"Header.h"
int main (void)
    return 0;
How to use #if - #else - #endif in main program ?
MrSoftware
Joined Oct 29, 2013
2,273
#if/else/endif are handled by the preprocessor, they never make it to the compiled code. There are many situations when you might use it, for example when writing multi-platform code:
C:
// Pick one!
#define WINDOWS
// #define LINUX
#ifdef WINDOWS
typedef HANDLE MyFileHandleType;
#elseif LINUX
typedef FILE* MyFileHandleType;
#else
#error unknown platform
#endif
main()
    MyFileHandleType fileHandle;
    #ifdef WINDOWS
    fileHandle = CreateFileW(...);
    #elseif LINUX
    fileHandle = fopen(....);
    #endif
The pre-processor would process this and the code that actually makes it to the compiler would be:
Code:
main()
You can do a ton more with pre-processor features, this is a just simple example. Your compiler likely has a setting you can turn on to make it output the code after the pre-processor has gone over it, so you can check the result.
@vajra
Joined May 2, 2018
154
I am having trouble to understand difference between Pre-processor Directive and micros
My understanding following are Pre-processor Directive
#include, #if, #ifdef, #ifndef, #else, #elif, #endif, #define, #undef, #line, #error, and #pragma are all preprocessing directives.
I found example of micros
Code:
#include <stdio.h>
// macro definition
#define LIMIT 5
int main()
    for (int i = 0; i < LIMIT; i++) {
        printf("%d \n",i);
    return 0;
MrSoftware
Joined Oct 29, 2013
2,273
The "directive" is the term that you type, such as #define, #if, etc.. these are the directives.
You use directives to make a macro. For example, here we use the "#define" directive to make the MIN macro:
C++:
#include <iostream>
using namespace std;
#define MIN(a,b) (((a)<(b)) ? a : b)
int main () {
   int i, j;
   i = 100;
   j = 30;
   cout <<"The minimum is " << MIN(i, j) << endl;
   return 0;
