I have an 8 channel mixer where the pre-mix gain doesn't seem to work properly. I tested all the adjustable channels and the error is the same. It doesn't matter if its the mic or line input. Adjusting the gain has nominal effect until they are nearly maxed out. At that point the channel level meter and output abruptly jumps into oversaturation. Since it occurs in all channels, I can't be sure it's a channel related issue, but more global. Attached is the manual and schematic of what I'm dealing with. Page 18 of the manual references the gain section in question. Could use a knowledgeable evaluation into troubleshooting ideas. Thx
