Luo Converter Variable Load
artmaster547
Joined Jan 6, 2016
409
Hi All
I am currently designning a dual output Luo Converter (Simulating in LTSpice) that takes in 12V and outputs +175V an -175V, one of the issues I am having at the moment is that the load will be variable but I need the output voltage to be constant the converter should deliver around 375W, can anyone make any suggestions on what techniques I can use for this?
Kind Regards
Art
27,311
OK, you are asking for a converter with regulated outputs at +/- 175 volts at just over an amp. at a 12 volts supply input that is a bit over 31 amps at 100% efficiency. It sounds like the best choice is a regulated inverter circuit. Those certainly exist and some are available on line. Check the "Schematics for free" website under the "power" category. That is my favorite, but there are lots of websites that provide circuits.
artmaster547
Joined Jan 6, 2016
409
Hi thank you for the suggestion could narrow it down to a specific schematic I had a look at your suggestion but there are so many options I am unsure of what will be the best option I would also like to simulate this in LTSpice
